在.NET下常用OpenCV进行图像处理工作,而常用的OpenCV库有Emgu CV和OpenCvSharp。OpenCvSharp使用习惯比EmguCV更接近原始的OpenCV,有详细的使用样例供参考。因此在网上收集了一些OpenCV的应用。
准备工作
打开VS,创建VB.NET的Winform项目。NuGet安装OpenCvSharp4的两个包。
在Form中引用
Imports OpenCvSharp
轮廓
vb.net2019- 调用 opencv_AI_LX的博客-CSDN博客_opencv vb
Private Sub showPict(ByVal fileName As String)
' Dim src As Mat = New Mat(fileName, ImreadModes.Grayscale)
Dim src As Mat = Cv2.ImRead(fileName, ImreadModes.Grayscale)
Dim dst As Mat = New Mat()
Cv2.Canny(src, dst, 50, 100)
Using (New Window("src image", src))
Using (New Window("dst image", dst))
Cv2.WaitKey()
End Using
End Using
End Sub
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
OpenFileDialog1.Filter = "Image Files(*.BMP;*.JPG;*.GIF;*.PNG)|*.BMP;*.JPG;*.GIF;*.PNG"
Dim fResult = OpenFileDialog1.ShowDialog() '打开文件选择框
If fResult = DialogResult.OK Then
Dim fileName As String = OpenFileDialog1.FileName '得到选择的文件
showPict(fileName)
End If
End Sub
调用本地摄像头
c# OpenCvSharp调用电脑本机摄像头 – 蒋智昊的博客 (chanpinxue.cn)
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
' 定义图像捕捉方式 从摄像头 , 注意 Windows下需要选择 VideoCaptureAPIs.DSHOW
Dim capture = New VideoCapture(0, VideoCaptureAPIs.DSHOW)
If Not capture.IsOpened() Then Return
capture.XI_OffsetX = 0 '以左上角为起点 坐标X
capture.XI_OffsetY = 0 '以左上角为起点 坐标Y
capture.FrameWidth = 640 '宽
capture.FrameHeight = 480 '高
capture.AutoFocus = True
Const sleepTime As Integer = 10
Dim window = New Window("cv")
'Mat作为图像的存储容器
Dim image = New Mat()
While True
capture.Read(image)
If image.Empty() Then Exit While
window.ShowImage(image)
'Windows窗体PictureBox加载
'picboxDest.Image = image.ToBitmap()
Dim flag As Integer = Cv2.WaitKey(sleepTime)
If flag >= 0 Then
Exit While
End If
Application.DoEvents()
End While
End Sub
面部识别
「图像处理」OpenCVSharp 调用摄像头及人脸识别_Raink_LH的博客-CSDN博客_opencvsharp虚拟摄像头
Private Sub Button3_Click(sender As Object, e As EventArgs) Handles Button3.Click
Dim video As FrameSource = Cv2.CreateFrameSource_Camera(0)
Cv2.NamedWindow("video")
While True
Dim frame As Mat = New Mat()
video.NextFrame(frame)
Dim faceFinder As OpenCvSharp.CascadeClassifier = New CascadeClassifier("E:桌面SamplesEasyPR-masteropencv2datahaarcascadeshaarcascade_frontalface_default.xml")
Dim eyeFinder As OpenCvSharp.CascadeClassifier = New CascadeClassifier("E:桌面SamplesEasyPR-masteropencv2datahaarcascadeshaarcascade_eye_tree_eyeglasses.xml")
Dim faceRects As Rect() = faceFinder.DetectMultiScale(frame)
Dim eyeRects As Rect() = eyeFinder.DetectMultiScale(frame)
If faceRects.Length > 0 Then
Cv2.Rectangle(frame, faceRects(0), New Scalar(0, 0, 255), 3)
End If
If eyeRects.Length > 1 Then
Cv2.Rectangle(frame, eyeRects(0), New Scalar(255, 0, 0), 3)
Cv2.Rectangle(frame, eyeRects(1), New Scalar(255, 0, 0), 3)
End If
Cv2.ImShow("video", frame)
Cv2.WaitKey(1)
End While
End Sub
对代码中的几个点做说明:
主要是检测到的人脸进行框出,并且实时显示
“E:桌面SamplesEasyPR-masteropencv2datahaarcascadeshaarcascade_frontalface_default.xml” 和
“E:桌面SamplesEasyPR-masteropencv2datahaarcascadeshaarcascade_eye_tree_eyeglasses.xml”
两个文件,这两个文件来自于Opencv(官方C 库),需要下载安装Opencv,在如上的的相应目录去找(我的安装在”E:桌面SamplesEasyPR-masteropencv2″目录)。
光流法检测图像位移及标注
基于opencvsharp的图像位移检测及相似点标注(光流金字塔法)_salt_bean_curd的博客-CSDN博客
'''''' 光流法,拼接两张图片 ''' ''' 第一张图片 ''' 第二张图片 '''Private Function MM(PrevimgColo As Mat, NextimgColo As Mat) As Mat Dim previmg As Mat = New Mat() Dim nextimg As Mat = New Mat() Cv2.CvtColor(PrevimgColo, previmg, ColorConversionCodes.BGR2GRAY) Cv2.CvtColor(NextimgColo, nextimg, ColorConversionCodes.BGR2GRAY) '特征点检测(角、点) Const MAX_Count As Integer = 500 Const Win_size As Integer = 10 '像素级检测特征点 Dim points1 As Point2f() points1 = Cv2.GoodFeaturesToTrack(previmg, MAX_Count, 0.01, 5, New Mat(), 3, False, 0.04) '亚像素级检测 Dim points1Sub As Point2f() points1Sub = Cv2.CornerSubPix(previmg, points1, New Size(Win_size, Win_size), New Size(-1, -1), New TermCriteria()) '迭代控制 Dim criteria As TermCriteria = New TermCriteria(CriteriaTypes.Eps And CriteriaTypes.Count, 20, 0.03) '光流金字塔,输出图二的特征点 Dim status As Byte() Dim err As Single() Dim points2 As Point2f() = New Point2f(points1Sub.Length - 1) {} Cv2.CalcOpticalFlowPyrLK(previmg, nextimg, points1Sub, points2, status, err) #Region "输出偏移量,两图像拼接,可视化结果" Dim Coll As Mat() = New Mat(1) {} Coll(0) = PrevimgColo Coll(1) = NextimgColo Dim mergeImg As Mat = New Mat() Cv2.HConcat(Coll, mergeImg) Dim points_temp As Point2f() = points2 Dim blue As Scalar = Scalar.Blue For num As Integer = 0 To points1Sub.Length - 1 If status(num) = 1 Then points_temp(num).X = PrevimgColo.Width Cv2.Line(mergeImg, CType(points1Sub(num), Point), CType(points_temp(num), Point), blue, 1, LineTypes.AntiAlias) End If Next #End Region Return mergeImg End Function ''' ''' 光流法,在一张图片上显示 ''' ''' 第一张图片 ''' 第二张图片 '''Private Function MM1(PrevimgColo As Mat, NextimgColo As Mat) As Mat Dim previmg As Mat = New Mat() Dim nextimg As Mat = New Mat() Cv2.CvtColor(PrevimgColo, previmg, ColorConversionCodes.BGR2GRAY) Cv2.CvtColor(NextimgColo, nextimg, ColorConversionCodes.BGR2GRAY) '特征点检测(角、点) Const MAX_Count As Integer = 500 Const Win_size As Integer = 10 '像素级检测特征点 Dim points1 As Point2f() points1 = Cv2.GoodFeaturesToTrack(previmg, MAX_Count, 0.01, 5, New Mat(), 3, False, 0.04) '亚像素级检测 Dim points1Sub As Point2f() points1Sub = Cv2.CornerSubPix(previmg, points1, New Size(Win_size, Win_size), New Size(-1, -1), New TermCriteria()) '迭代控制 Dim criteria As TermCriteria = New TermCriteria(CriteriaTypes.Eps And CriteriaTypes.Count, 20, 0.03) '光流金字塔,输出图二的特征点 Dim status As Byte() Dim err As Single() Dim points2 As Point2f() = New Point2f(points1Sub.Length - 1) {} Cv2.CalcOpticalFlowPyrLK(previmg, nextimg, points1Sub, points2, status, err) #Region "输出偏移量,可视化结果" Dim mergeImg As Mat = NextimgColo Dim blue As Scalar = Scalar.Blue Debug.Print("===========") For num As Integer = 0 To points1Sub.Length - 1 If status(num) = 1 Then Cv2.Line(mergeImg, CType(points1Sub(num), Point), CType(points2(num), Point), blue, 1, LineTypes.AntiAlias) DistanceBetween(points1Sub(num).X, points1Sub(num).Y, points2(num).X, points2(num).Y) End If Next #End Region Return mergeImg End Function Public Function DistanceBetween(ByVal X1 As Single, ByVal Y1 As Single, ByVal X2 As Single, ByVal Y2 As Single) As Single ' Calculate the distance between two points, given their X/Y coordinates. ' The short version... DistanceBetween = Math.Sqrt((Math.Abs(X2 - X1) ^ 2) (Math.Abs(Y2 - Y1) ^ 2)) ' The longer version, to illustrate how it works... Dim Horizontal As Single, Vertical As Single Horizontal = Math.Abs(X2 - X1) Vertical = Math.Abs(Y2 - Y1) DistanceBetween = Math.Sqrt((Horizontal * Horizontal) (Vertical * Vertical)) If DistanceBetween > 2 Then Debug.Print(Format(DistanceBetween, "#00.00") & vbTab & Format(X1 - X2, "#00.00") & vbTab & Format(Y1 - Y2, "#00.00")) End If End Function Private Sub Button4_Click(sender As Object, e As EventArgs) Handles Button4.Click Dim video As FrameSource = Cv2.CreateFrameSource_Camera(0) Cv2.NamedWindow("video") While True Dim frame0 As Mat = New Mat() video.NextFrame(frame0) Dim flag As Integer = Cv2.WaitKey(1000) If flag >= 0 Then Exit While End If Dim frame1 As Mat = New Mat() video.NextFrame(frame1) Cv2.ImShow("video", MM1(frame0, frame1)) Cv2.WaitKey(1) End While End Sub
MM:
MM1:
