C# 上位机开发 modbus rtu master 通讯协议类源码
1、读取保持型寄存器 功能码0x03
2、预置单字保持型寄存器 功能码0x06
3、预置双字保持型寄存器 功能码0x10
4、读取输出线圈 功能码0x01
5、读取输入线圈 功能码0x02
6、强制单线圈 功能码0x05
using System;
using System.Collections.Generic;
using System.IO.Ports;
using System.Linq;
using System.Text;
using System.Threading;
using System.Threading.Tasks;
namespace IProgram
public class Modbus
//定义串口类对象
private SerialPort MyCom;
//定义CRC校验高低位
private byte ucCRCHi = 0xFF;
private byte ucCRCLo = 0xFF;
//定义接收字节数组
byte[] bData = new byte[1024];
//byte mReceiveByte;
//int mReceiveByteCount = 0;
//定义设备地址
int CurrentAddr;
int iMWordLen;
int iMBitLen;
//定义返回报文
string strUpData = string.Empty;
public Modbus(ComPort sp)
// MyCom = new SerialPort();
MyCom = sp;
#region 打开关闭串口方法
/// <summary>
/// 打开串口方法【9600 N 8 1】
/// </summary>
/// <param name="iBaudRate">波特率</param>
/// <param name="iPortNo">端口号</param>
/// <param name="iDataBits">数据位</param>
/// <param name="iParity">校验位</param>
/// <param name="iStopBits">停止位</param>
/// <returns></returns>
public bool OpenMyComm(int iBaudRate, string iPortNo, int iDataBits, Parity iParity, StopBits iStopBits)
try
//关闭已打开串口
MyCom.Close();
if (MyCom.IsOpen)
MyCom.Close();
//设置串口属性
MyCom.BaudRate = iBaudRate;
MyCom.PortName = iPortNo;
MyCom.DataBits = iDataBits;
MyCom.Parity = iParity;
MyCom.StopBits = iStopBits;
MyCom.ReceivedBytesThreshold = 1;
MyCom.DataReceived += new SerialDataReceivedEventHandler(MyCom_DataReceived);
MyCom.Open();
return true;
catch
return false;
/// <summary>
/// 关闭串口方法
/// </summary>
public void ClosePort()
MyCom.Close();
#endregion
#region //所有输出口打开
/// <summary>
/// 所以输出口打开
/// </summary>
public void SetAllOn()
byte[] SendCommand = new byte[11] { 0x01,0x0F,0x00,0x00,0x00,0x10,0x02,0xFF,0xFF,0xE3,0x90 };
MyCom.QueryBytes(SendCommand, 8, 2000);
#endregion
#region //所有输出口关闭
public void SetAllOff()
byte[] SendCommand = new byte[11] { 0x01, 0x0F, 0x00, 0x00, 0x00, 0x10, 0x02, 0x00, 0x00, 0xE2, 0x20 };
#endregion
#region //获取输入状态
/// <summary>
/// 获取输入信号状态
/// </summary>
/// <param name="X">输入口位</param>
public bool GetInput(int X)
int my_cmd = 0;
byte[] Static = ReadInputStatus(0x01, 0x00, 0x08);
my_cmd = 1 << (X);
if ((Static[3] & my_cmd) == my_cmd)
Thread.Sleep(100);
return true;
return false;
#endregion
public void DioOutput(int Y,int time)
SetOut(Y, true);
Thread.Sleep(time);
SetOut(Y, false);
#region //指定端口输出
/// <summary>
/// 设置端口输出
/// </summary>
/// <param name="Y">输出端口位</param>
/// <param name="En"></param>
public bool SetOut(int Y,bool En)
int my_cmd;
if ( ForceCoil(0x01,Y,En))
Thread.Sleep(200);
byte[] Static = ReadOutputStatus(0x01, 0, 10);
if(En)
my_cmd = 0;
my_cmd = 1 << (Y);
return true;
else
my_cmd = 0xFFFF;
my_cmd = 0 << (Y);
return true;
return false;
#endregion
//#region 串口接受数据事件
///// <summary>
///// 串口接受数据事件
///// </summary>
///// <param name="sender"></param>
///// <param name="e"></param>
void MyCom_DataReceived(object sender, SerialDataReceivedEventArgs e)
while (MyCom.BytesToRead > 0)
mReceiveByte = (byte)MyCom.ReadByte();
bData[mReceiveByteCount] = mReceiveByte;
mReceiveByteCount += 1;
if (mReceiveByteCount >= 1024)
//清除输入缓存区
MyCom.DiscardInBuffer();
return;
#region 读取保持型寄存器 功能码0x03
/// <summary>
/// 读取保持型寄存器 功能码0x03
/// </summary>
/// <param name="iDevAdd">从站地址</param>
/// <param name="iAddress">起始地址</param>
/// <param name="iLength">长度</param>
public byte[] ReadKeepReg(int iDevAdd, int iAddress, int iLength)
//byte[] ResByte = null;
iMWordLen = iLength;
CurrentAddr = iDevAdd;
//第一步:拼接报文
byte[] SendCommand = new byte[8];
SendCommand[0] = (byte)iDevAdd;
SendCommand[1] = 0x03;
SendCommand[2] = (byte)((iAddress - iAddress % 256) / 256);
SendCommand[3] = (byte)(iAddress % 256);
SendCommand[4] = (byte)((iLength - iLength % 256) / 256);
SendCommand[5] = (byte)(iLength % 256);
Crc16(SendCommand, 6);
SendCommand[6] = ucCRCLo;
SendCommand[7] = ucCRCHi;
//第二步:发送报文
try
//MyCom.Write(SendCommand, 0, 8);
return MyCom.QueryBytes(SendCommand, 8, 2000);
catch (Exception)
return null;
//第三步:解析报文
//mReceiveByteCount = 0;
//Thread.Sleep(300);
//ResByte = HexStringToByteArray(this.strUpData, 3, 2);
//return ResByte;
#endregion
#region 预置单字保持型寄存器 功能码0x06
/// <summary>
/// 预置单字保持型寄存器 功能码0x06
/// </summary>
/// <param name="iDevAdd"></param>
/// <param name="iAddress"></param>
/// <param name="SetValue"></param>
public bool PreSetKeepReg(int iDevAdd, int iAddress, int SetValue)
byte[] ResByte;
//第一步:拼接报文
SendCommand[1] = 0x06;
SendCommand[4] = (byte)((SetValue - SetValue % 256) / 256);
SendCommand[5] = (byte)(SetValue % 256);
try
//第二步:发送报文
catch (Exception)
return false;
Thread.Sleep(100);
//第三步:解析报文
ResByte = HexStringToByteArray(this.strUpData, 0, 0);
return ByteArrayEquals(SendCommand, ResByte);
#endregion
#region 预置双字保持型寄存器 功能码0x10
/// <summary>
/// 预置双字保持型寄存器 功能码0x10
/// </summary>
public bool PreSetFloatKeepReg(int iDevAdd, int iAddress, float SetValue)
byte[] ResByte;
byte[] SendCommand = new byte[13];
SendCommand[1] = 0x10;
SendCommand[4] = 0x00;
SendCommand[5] = 0x02;
SendCommand[6] = 0x04;
byte[] bSetValue = BitConverter.GetBytes(SetValue);
SendCommand[7] = bSetValue[3];
SendCommand[8] = bSetValue[2];
SendCommand[9] = bSetValue[1];
SendCommand[10] = bSetValue[0];
Crc16(SendCommand, 11);
SendCommand[11] = ucCRCLo;
SendCommand[12] = ucCRCHi;
try
MyCom.Write(SendCommand, 0, 13);
catch (Exception)
return false;
Thread.Sleep(100);
byte[] byteTemp = GetByteArray(ResByte, 0, 6);
Crc16(byteTemp, 6);
byte[] bytecrc = GetByteArray(ResByte, 6, 2);
if (ByteArrayEquals(GetByteArray(SendCommand, 0, 6), byteTemp) && bytecrc[0] == ucCRCLo && bytecrc[1] == ucCRCHi)
return true;
else
return false;
#endregion
#region 读取输出线圈 功能码0x01
/// <summary>
/// 读取输出线圈 功能码0x01
/// </summary>
/// <param name="iLength"></param>
public byte[] ReadOutputStatus(int iDevAdd, int iAddress, int iLength)
if (iLength % 8 == 0)
iMBitLen = iLength / 8;
else
iMBitLen = iLength / 8 + 1;
//第一步:拼接报文
SendCommand[1] = 0x01;
try
return MyCom.QueryBytes(SendCommand, 7, 2000);
catch (Exception)
return null;
//Thread.Sleep(100);
//return HexStringToByteArray(this.strUpData, 3, 2);
#endregion
#region 读取输入线圈 功能码0x02
/// <summary>
/// 读取输入线圈 功能码0x02
/// </summary>
public byte[] ReadInputStatus(int iDevAdd, int iAddress, int iLength)
else
//第一步:拼接报文
SendCommand[1] = 0x02;
try
return MyCom.QueryBytes(SendCommand, 6, 2000);
catch (Exception)
return null;
//return MyCom.QueryBytes(SendCommand, 8, 2000);
#endregion
#region 强制单线圈 功能码0x05
/// <summary>
/// 强制单线圈 功能码0x05
/// </summary>
public bool ForceCoil(int iDevAdd,int iAddress,bool SetValue)
//byte[] ResByte;
SendCommand[1] = 0x05;
if (SetValue)
SendCommand[4] = 0xFF;
else
SendCommand[5] = 0x00;
try
catch (Exception)
return false;
Thread.Sleep(100);
// ResByte = HexStringToByteArray(this.strUpData,0,0); //接收的数组数据
// return ByteArrayEquals(SendCommand, ResByte);
return true;
#endregion
#region 自定义方法
/// <summary>
/// 报文转换字节数组(自定义截取)
/// </summary>
/// <param name="S"></param>
/// <param name="start"></param>
/// <param name="end"></param>
private byte[] HexStringToByteArray(string S, int start, int end)
byte[] Res = null;
if (S != null && S.Length > start + end)
string[] str = S.Trim().Split(' ');
string[] Result = new string[str.Length - start - end];
for (int i = 0; i < Result.Length; i++)
Result[i] = str[i + start];
Res = new byte[Result.Length];
Res[i] = Convert.ToByte(Result[i], 16);
return Res;
/// <summary>
/// 判断两个字节数组是否完全一致
/// </summary>
/// <param name="b1"></param>
/// <param name="b2"></param>
private bool ByteArrayEquals(byte[] b1, byte[] b2)
if (b1.Length != b2.Length) return false;
if (b1 == null || b2 == null) return false;
for (int i = 0; i < b1.Length; i++)
if (b1[i] != b2[i])
return false;
return true;
/// <summary>
/// 自定义截取字节数组
/// </summary>
/// <param name="byteArr"></param>
/// <param name="length"></param>
private byte[] GetByteArray(byte[] byteArr, int start, int length)
byte[] Res = new byte[length];
if (byteArr != null && byteArr.Length > length)
for (int i = 0; i < length; i++)
Res[i] = byteArr[i + start];
return Res;
#endregion
#region CRC校验
private static readonly byte[] aucCRCHi = {
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
private static readonly byte[] aucCRCLo = {
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7,
0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E,
0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09, 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9,
0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC,
0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32,
0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D,
0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A, 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38,
0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF,
0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1,
0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4,
0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F, 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB,
0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA,
0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0,
0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97,
0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C, 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E,
0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89,
0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83,
0x41, 0x81, 0x80, 0x40
private void Crc16(byte[] pucFrame, int usLen)
int i = 0;
ucCRCHi = 0xFF;
ucCRCLo = 0xFF;
UInt16 iIndex = 0x0000;
while (usLen-- > 0)
iIndex = (UInt16)(ucCRCLo ^ pucFrame[i++]);
ucCRCLo = (byte)(ucCRCHi ^ aucCRCHi[iIndex]);
ucCRCHi = aucCRCLo[iIndex];
#endregion
